Dear all, could you please share the link for downloading the latest UDB file autoderatories,
more over it is also observed that most of material in the library does not posses shrinkage details, which becomes must for performing shrink analysis,
pl advice
Thanks, Ramabalaji.K
the material database is updated together with software release, and will be available when installing the software.
You can access the latest release of Autodesk Moldflow Insight 2012 Service Pack 2, at the subscription center:
http://subscription.autodesk.com/
Berndt
Thank you sir,
but the for user who do not update their software licence with AMC it becomes impossible to get acess to latest material database,
requesting the concern's to take in account of the mentioned issue and create a centralised data access point,
regards, ramabalaji
AMC doesn't have material database.
The material data are saved in the mfr file.
If we use AMI 2011, can we update our material database with AMI2012 SP2 ?
At the mioment, there is no online material database, although there are plenty of valid use cases for this.
Having said that, the material databases are tightly related to the solvers, so you would have to be careful with these things.
