Dear all,
some of the material not available in our moldfloe material database.
i want to import new material into database.
i want to know is it possible?
if possible means how to import?
and which format required to import?
pls help me anyone....
Solved by nordhb. Go to Solution.
the format used for material database is called udb, a Moldflow specific file.
It is possible to have a personal databases.
In Help look in:
Materials and databases
Materials and databases > Material databases
Materials and databases > Material databases > Personal databases
What you can do:
- Contact the material supplier and ask for an udb-file for the material
- If you have measured data, raw data, of material you can contact
datafittingmoldflow@autodesk.com
and get measured data fitted and an udb-file for analysis in return.
(material supplier might have measured raw data of the material?)
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
