Discussion Groups
Simulation Moldflow Insight
p.hammer
map heating results of part insert to moldflow?
205 Views, 3 Replies
04-22-2014 03:30 AM
I did a heating simulation in CFD for a part insert.
Now I would like to map these results as starting temperature for a moldflow analysis.
Is this possible?
Philipp
Please use plain text.
madhukeshwart
Re: map heating results of part insert to moldflow?
05-11-2014 10:03 AM in reply to: p.hammer
At present it is not available... But
If you have pre-heat temperature.. you can assign one value of temperature to insert. But cant map different temperature for each element
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Active Contributor
phammer
05-11-2014 11:13 PM in reply to: madhukeshwart
HI everybody,
answer I got from support was interesting.
Only workaround they had was to split the insert in several bodies and assing different starting temperature.
Greeting Philipp
madhukeshwart
05-14-2014 09:14 AM in reply to: phammer
it is like for each element ...assign a value..!!
Madhukeshwar Talwar
09600060862
