I did a heating simulation in CFD for a part insert.
Now I would like to map these results as starting temperature for a moldflow analysis.
Is this possible?
Philipp
At present it is not available... But
If you have pre-heat temperature.. you can assign one value of temperature to insert. But cant map different temperature for each element
HI everybody,
answer I got from support was interesting.
Only workaround they had was to split the insert in several bodies and assing different starting temperature.
Greeting Philipp
