Discussion Groups
Simulation Moldflow Insight
Valued Contributor
jk_moldflow
dual domain and 3D image display difference
801 Views, 8 Replies
02-09-2011 02:41 AM
Hello all,
I am using Autodesk moldflow insight 2011.
Windows XP Professional x64 Service Pack 2.
I am facing display image difference between Dual domain and 3D images (normal and with result image) as shown below. some of my customers are questioning this problem.Please share your experiences.
Thanks in advance
JK
Please use plain text.
New Member
SebastianKammer
Re: dual domain and 3D image display difference
11-01-2012 09:39 PM in reply to: jk_moldflow
In 3D meshed parts the 'gate' has to be part of the solid 3D model that is imported to moldflow.
In 3D mesh the 'gate' cannot be build in moldflow, while runner and sprue makes no problems as you can see in the picture above.
ben_mendenhall
03-06-2014 06:12 AM in reply to: jk_moldflow
Its just a glitch, Should be fixed in 2015 version.
Valued Contributor
tim.vanast
03-10-2014 11:09 AM in reply to: ben_mendenhall
Yep, it's a glitch.  The code calculates correctly but just displays it incorrectly.
madhukeshwart
03-11-2014 03:03 AM in reply to: tim.vanast
 This problem existing with mold flow since long & it is  expected  to be fixed with every time
they  release a new version. At least we expect it should be fixed in next service packs.
Even though it will calculates properly, but some time we feel difficult to convince the end user.
This visualization bug should be fixed at the earliest
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Distinguished Contributor
mayur_dhumal
03-20-2014 04:49 AM in reply to: jk_moldflow
This issue seems to be fixed with latest Version of Synergy. :smileyvery-happy:
You can close this Issue as accepted.
Mayur
Active Member
Halasur
04-01-2014 04:17 AM in reply to: mayur_dhumal
No not yet fixed
Board Manager
raalteh
04-01-2014 09:35 AM in reply to: Halasur
The display issue has been identified and should be availble in the next release.
As Tim mentioned in his response, the solver calculates it correctly, but the user interface had a problem.
Hanno van Raalte,
Product Manager for Autodesk Simulation Moldflow products
madhukeshwart
04-04-2014 02:12 AM in reply to: raalteh
It has been pending since long. Moldflow team should have taken on priority.
Madhukeshwar Talwar
09600060862
