hello everyone,
newly i am going todo analysys for 2 colour mold ( co injection mold). anyone help me to wher i can get this information and procedure?. because this is my first project about co injection mold...
I suggest you start with Autodesk Simulation Moldflow Insight 2014 Help:
You can get quite some information from:
ASMI Help > User's Guide > Molding processes > Co-injection and Bi-injection molding processes
ASMI Help > User's Guide > Molding processes > Co-injection and Bi-injection molding processes >
> Co-injection analysis > Co-injection molding overview
In Autodesk Simulation Moldflow Insight 2014 Co-injection and Bi-injection can be simulated.
Co-injection involves the injection of two different materials using the same injection location.
Bi-injection is the injection of two different materials at separate injection locations, with independent process controls.
Hope this helps as a starting point for you.
Berndt
you can do following for all mesh types of Midplane, Dual Domain and 3D:
Fill + Pack + Overmolding Fill + Overmolding Pack.
For 3D mesh type also:
Fill + Pack + Overmolding Fill + Overmolding Pack +Warp.
The Overmolding analysis consists of a 2-step process where a normal Fill+Pack analysis is performed on the first cavity (first component stage),
which is then followed by a Fill+Pack analysis on the overmolding cavity (overmolding stage).
The consecutive overmolding stage on the second cavity uses a different material from the first analysis,
and the first component temperatures are used as the initial temperatures.
Hope this clarifies.
Berndt
