Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Windows Desktop composition problem
5 REPLIES 5
piepCAE
752 Views, 5 Replies
I'm having a problem with Moldflow 2015 I never had before with any previous release. When I open a study the windows desktop composition is deactivated, as well as the aeropeek. I checked that I'm not running Moldflow in any compatibility mode, I installed the software as an administrator, etc... Does this happen to anybody else? Thank you.
Carlos
5 REPLIES 5
zhangchar
in reply to: piepCAE
If you haven't had latest graphic driver, could you try to install latest graphich driver and see if it fixes the problem.
Charlie
piepCAE
in reply to: zhangchar
Problem solved! I could swear I had the latest drivers..
thank you!
piepCAE
I'm sorry Charlie, after all that doesn't seem to be the problem. The desktop composition is deactivated after opening a study, not a project. I only opened a project to test if it was a driver's problem... Any more ideas?
caitlin.tschappat
Hello piepCAE,
Could you try opening the graphics card control panel (for me, I right click on my desk top>NVIDIA Control Panel) Inside the control panel, 3D Settings> Manage 3D setting, and try switching the Global presets to "3D App - Visual Simulation"
Please advise if this works.
Thank you,
Caitlin
Caitlin Tschappat
piepCAE
in reply to: caitlin.tschappat
Hello Caitlin,
Indeed it works! Thank you very much.
Carlos
