I'm having a problem with Moldflow 2015 I never had before with any previous release. When I open a study the windows desktop composition is deactivated, as well as the aeropeek. I checked that I'm not running Moldflow in any compatibility mode, I installed the software as an administrator, etc... Does this happen to anybody else? Thank you.
Carlos
Solved by caitlin.tschappat. Go to Solution.
Solved by zhangchar. Go to Solution.
If you haven't had latest graphic driver, could you try to install latest graphich driver and see if it fixes the problem.
Charlie
I'm sorry Charlie, after all that doesn't seem to be the problem. The desktop composition is deactivated after opening a study, not a project. I only opened a project to test if it was a driver's problem... Any more ideas?
Hello piepCAE,
Could you try opening the graphics card control panel (for me, I right click on my desk top>NVIDIA Control Panel) Inside the control panel, 3D Settings> Manage 3D setting, and try switching the Global presets to "3D App - Visual Simulation"
Please advise if this works.
Thank you,
Caitlin
