Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
**WARNING 702460**
6 REPLIES 6
866 Views, 6 Replies
**WARNING 702460**
when i am running a cool analysis i am getting the following error
**WARNING 702460** Beam element 33324 hasno circuit attribute assigned to it .check that a coolant inlet has been assigned to this circuit.
 then how can  i resolve this problem?  i would appreciate receiving datails regarding it above.
6 REPLIES 6
about this question,i have created original file which is mpi format.pl download and  unzip befor running in the Autodesk moldflow insight 2010 version. have a note have can 't delete on the "dumb layer" of the file. any idea to solve it, i can send it to them(because it is too large,can't attachment
skype name:kenny0755                  can be discussion on line
Check the connectivity of the circuit. ie, make sure all beams are connected.
Thanks for your reply,actually i have already checked all this,but the ploplem was somewhere else.may i have your Email?i send the moldflow file to you
    Regards!
113iC17F6ECDC131BCC8111i4CCC84960A92DB1C
You may have a double beam element somewhere. One that is inside a circuit so maybe you can't see it.
