Discussion Groups
Simulation Moldflow Insight
psofiagida
Volumetric shrinkage
222 Views, 2 Replies
01-13-2014 05:51 AM
Hi all,
i am using Moldflow Insight 2012. I was checking the volumetric shrinkage result. My initial melt temperature was 250 C. Shrinkage observed was 1.9-2%. However, when i decreased the Tmelt down to 230 and 220 C, no change on volumetric shrinkage was observed. I was expecting for it to drop. The results i acquired were exactly the same.
Is there sth faulty with the version or i am doing sth wrong in the process settings dialog ?
(I am running only a Fill+Pack analysis, with NO cooling channels involved. Part geometry: Center-gated disk).
Please use plain text.
Product Support
paul.larter
Re: Volumetric shrinkage
01-23-2014 02:49 AM in reply to: psofiagida
When you modify the values in process settings and click Finish to close the dialog. Are you being asked to Delete, Create copy or Cancel?
If you do not see this then you could mean the second analysis has not picked up on your changes.
Look at yout analysis logs to make sure of the process settings used.
Regards
Paul
Paul Larter
psofiagida
01-30-2014 07:41 AM in reply to: paul.larter
yes it asks me to delete and the analysis again. even in the logs, Tmelt = 230 C. However, shrinkage is more or less the same. Maybe the constant packing profile i am using is the reason.
