volumetric shrinkage should be less than the prescribed values, because volumetric shrinkage shows as a percent of original volume.whereas the shrinkage values in the data sheet is with respect to dimensions. so if you have the value of volumetric shrinkage more than shrinkage values, then for sure you part is shrinking more , due to insufficient packing and other parameters.
