Discussion Groups
Simulation Moldflow Insight
Member
w18855
Visible sink mark depth
679 Views, 6 Replies
12-29-2011 02:49 PM
Hello~
I am curious what size would be the visible sink mark during the sink mark estimate. Anybody has idea if 0.025mm would be visible on actual part?
Thank you!
Please use plain text.
Valued Contributor
nishit78
Re: Visible sink mark depth
12-30-2011 06:10 AM in reply to: w18855
I think it will depend on the light conditions and the angle at which you are looking at that area of the part. Also any surface texturing will help in hiding those marks. Personally, i think, under a certain configuration of these factors you will see it but numerically speaking it is not a high value.
Autodesk has a product called "showcase" that helps visualize what effects these factors can have.
You can also use the scaling option in the deflection tab of plot properties for that plot (sink-marks shaded) to exaggerate the visual effect
New Member
amwafwcel1
05-07-2013 06:44 PM in reply to: w18855
It depends on the what material you use , for the big shrinkage of the material, 0.01mm also can affect the appearance of the product.
madhukeshwart
05-27-2013 08:06 PM in reply to: w18855
Sink estimate to be less than 0.03 for most of parts is quite ok.  it can be  up to 0.05 for granied/painted.
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
New Member
tbloink
05-02-2014 11:02 AM in reply to: madhukeshwart
What is granied? Would 0.05 mm apply to textured parts?
madhukeshwart
05-03-2014 05:09 AM in reply to: tbloink
With textured or grained
Madhukeshwar Talwar
09600060862
New Member
nitinhadpe
05-04-2014 10:15 PM in reply to: w18855
Yes, I do agree with Madhukeshwar.
Midplane:
0.003 mm for non textured / mirror polished surface
upto 0.05 mm for textured (may be any kind)
