Discussion Groups
Simulation Moldflow Insight
MFI-MaF
Using Variables in macros
304 Views, 9 Replies
11-13-2013 01:15 AM
Hello everybody,
I'm working on a macro to automate the output of my wanted result files. I made an Input box where the user put in the Node ID and the path of the result file. I've tried to place the variables at the wanted positions in the script, but Moldflow ignores the input.
Here is the problematic part of my macro:
Does anybody know how i can solve the problem with those two variables?
UserInput = Inputbox("Call node:")
Pfad = Inputbox ("Where do you want to place the resultfile? (z.B.: c:\...\):")
SetLocale("en-us")
Set Synergy = CreateObject("synergy.Synergy")
Synergy.SetUnits "Metric"
Set StudyDoc = Synergy.StudyDoc()
Set EntList = StudyDoc.CreateEntityList() '* create an empty entity list
Set PlotManager = Synergy.PlotManager()
Set Plot = PlotManager.CreatePlotByDsID(1180, True)
Plot.SetXYPlotShowLegend True
Set Viewer = Synergy.Viewer()
Set Plot = Viewer.ActivePlot()
Set Plot = PlotManager.FindPlotByName2("Pressure:XY Plot", "Pressure")
EntList.SelectFromString ("& UserInput &")  '* popoulate the entity list
Plot.AddXYPlotCurve(EntList)  '* plot the curve of entity
Viewer.ShowPlot Plot
Plot.SaveXYPlotCurveData ("& Pfad")
EntList.SelectFromString ("& UserInput")  'First problem line
Plot.SaveXYPlotCurveData ("& Pfad")         'second problem line
My next problem is that this code just works for pressure on this way. If I want to use the macro for fiber orientation I have to open the wanted result before runnung the macro:
setLocale("en-US")
Set probePlot = Viewer.ActivePlot()
Set VectorA = Synergy.CreateVector()
Set VectorB = Synergy.CreateVector()
VectorA.SetXYZ -4.34, 0, -9.6	'ERSTE VEKTORKOORDINATE (Startpunkt)'
VectorB.SetXYZ -4.34, 3, -9.6	'ZWEITE VEKTORKOORDINATE (Endpunkt)'
probePlot.AddProbePlotProbeLine VectorA, VectorB'
probePlot.SaveXYPlotCurveData "& Pfad" '
probePlot.Regenerate
Thank you
Please use plain text.
MFI-MaF
Re: Using Variables in macros
11-14-2013 12:53 AM in reply to: MFI-MaF
my first problem, I solved on myself. My fault was a wrong input
and this is the correct way:
EntList.SelectFromString (""& UserInput )
 But if someone has an idea for my second problem, it would be very nice if you post it :-)
Product Support
nordhb
11-14-2013 01:15 AM in reply to: MFI-MaF
change the row to:
Plot.SaveXYPlotCurveData (Pfad)
 That should do it.
Berndt
Berndt Nordh
