Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Unrealistic Temperature plot
2 REPLIES 2
klp2kor
484 Views, 2 Replies
In a simmetrical part, I observed an unrealistic flow front temperature difference. Please refer the attached images.
I have also included the snapshot of 3D mesh quality used.
Can someone comment, what could be the actual cause for this variation and how to fix it.
Thanks and Regards,
KL
2 REPLIES 2
madhukeshwart
in reply to: klp2kor
This is very common question, rises when you using 3d analysis.
Option 1- Re-mesh the part and re-run the analysis.
Option 2- Re-mesh with fine elements and don't correct much the mesh after converting to 3D.
Option 3- some variaitions, you can ignore and take decision, when you are sure, it is problem of 3d analysis .
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
klp2kor
Thanks Madhukesh.
