Good day,
I am perplexed a bit by the results I have right here. I've run a Cool+Fill+Pack+Warp analysis with a full mold. I want to check the time when the whole part can be ejected (Whole part is under Teject.).
-At first I've checked Time to reach..., Part result under Cool. It shows me ~40 secs. I add ~4 secs for filling getting a ~44 secs total measured from the start of the filling phase.
-Then I've checked Temperature result under Fill. Set the Scaling of this result to show only a temperature range above ejection temperature (And've removed the tick from "Extend color".). So this shows a closed volume of polymer above the ejection temperature at a given time. I've animated the result until there was only the "empty", translucent model and assumed that that is the time when the whole volume of the part is under the ejection temp I'd set. And got 28 secs.
So ~44 s =<> ~28 s. ???
Thanks in advance,
Balázs
The result in cooling analysis is a little different from the one in the flow analysis. In that, the cooling analysis assumes that the entire part is at the melt temp and it cools down to the ej. temp. However, in the flow analysis it takes into account the dynamics of fill and packing phases giving a more realistic result in my opinion.
All that being said, i dont know why you are getting such a high differential. I usually see differences but not of such magnitude.
One thing i'd suggest (and it is the same as what you are doing right now) but go to the flow analysis temperature result, set the scale back to "all frames" and then go to the methods tab and change to contour-->single contour-->enter the ej temp. This will show you part volume above the ej temp through the entire cycle. This pretty much does the same as what you have done with scaling but is just something different to confirm the times.
Let me know if this makes sense and if you find out what the problem is
Ni****
Hi Ni****,
Thanks for Your kind help!
"The result in cooling analysis is a little different from the one in the flow analysis. In that, the cooling analysis assumes that the entire part is at the melt temp and it cools down to the ej. temp. However, in the flow analysis it takes into account the dynamics of fill and packing phases giving a more realistic result in my opinion."
I know that Cool - as an initial condition - starts with the cavity filled with melt at Tmelt. And after Cool is done, Flow uses the average temperatures at the cavity-mold interface from Cool's calculations AND takes shear heating (etc.) into consideration.
"One thing i'd suggest (and it is the same as what you are doing right now) but go to the flow analysis temperature result, set the scale back to "all frames" and then go to the methods tab and change to contour-->single contour-->enter the ej temp. This will show you part volume above the ej temp through the entire cycle. This pretty much does the same as what you have done with scaling but is just something different to confirm the times."
I've tried that and got exactly the same results! 🙂
Balázs
could you give this plot setup at try:
Cool: Time to reach ejection temperature, part
right-click and Properties
tab Methods : Countour - Single contour
tab Animation : Animate result over : Single dataset
and Show lower values
and Animate result at: last time step
tab Scaling: All Frames
Above shows areas at ejection temperature by time.
The result from an analysis similar to yours gives reasonable results for
comparing Fill+Pack : Temperature.
See attached plot. (Ejection temp 101C)
(The temperature at flow front is close to melt temperature.)
Berndt
Hi Bernd!
I've done what You have adviced and this is what I have right now (See attachements!)
Each results needs one timestep (~1 s) to cool the part under the ejection temperature but even with adding the filling time (~4,7 s) to the Time to reach results (~28,6 s) we won't get the Flow's Temperature (~37,5). But they are close and the difference might come from Flow's additional shear heating calculation.
What do You think?
Cheers, Balázs
After reading your post again i realized that i did not understand why you need to add fill time to your "Time to reach ej temp, part" result. This result is at the end of I+P+C time which you specify in the cooling analysis.
Am i missing something here
Hi Ni****!
If You start to examine Cool's Time to reach result, You'll see that at 0 s the cavity is full! That's because Cool assumes that the cavity is filled with molten polymer at melt temperature. So to compare my results (Flow's Temp and Cool's Time to), You have to add the filling time to the Time to reach result to get the a real Time to reach ejection result.
And no, this result is not at IPC. Time to reach can be animated through time (Check Bernd's previous comment!).
Thank You,
Balázs
Yes I understand the result can be animated. What i meant was that the result is created over the I+P+C time.
If what you say is correct then why is the cooling process setting input called "inject+pack+cool time"
If you run a flow anlaysis afterwards it subtracts the fill + pack time from the I+P+C time to get the cooling time for the subsequent result.
This was my understanding.
I just checked the help info. This is what it states
The Time to reach ejection temperature, part result is produced by a Cool analysis and shows the time required to reach the ejection temperature, measured from the start of the cycle.
I hope we can clarify this.
And right after that it states:
"At the start of the measurement, the part is assumed to be filled with material at its melt temperature (Tmelt)."
But that does not mean you have to add the fill time. Atleast not that i am aware of. This is turning out to be a good learning for me. I hope someone at moldflow can help.
Yes, it would be for me also.
However I think that You have. I mean try to animate Time to reach from 0 till the end. At zero, there IS material in the cavity... That was my main doubt when I'd asked about it in the first place back in august or what.
I think the part being filled with the resin at melt temp is just an initial condition "assumption" necessary for a stand alone cooling analysis (which i feel is a great approximation not considering fill+pack)
Personally i do not use the "time to reach" result very much for that exact reason. It is just an approximate result in absence of any other info (fill+pack)
I'd really appreciate if someone from moldflow looks as this and helps.
Balaz.. Are you based in the U.S.?
Yes that is why i asked but i can't access skype and those things at work.
I also wanted to say that the main difference between the "time to reach" and "temperature" result will be evident in the gate area.
In the "time to reach" the gate area will freeze just as any other area in the part
However, in the "temperature" result it will freeze differently.
In my experience, this is true for every single part that i have analyzed.
This is on a slightly different note but just wanted to point out a key difference between these two results.
Can you contact me over skype from home, if You have time? It would be interresting to discuss some things! (I'll try to be awake for an extended period of time if You'll have some time this evening. (It's already 16:35 at here...)
In terms for hrs it will take me another 6 hrs to do that. It is 11:40 a.m. here I get home at around 5:00-5:30 p.m.
So will after 6 hrs be ok.
Ok i will connect over skype.
But anyway, our current discussion is still unresolved right?????
You say we add the fill time
I saw we do not add the fill time
Hahahahaha
