Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Thickness vba script is in MF 2015 for 3D part notworking
5 REPLIES 5
phammer
712 Views, 5 Replies
Hi everybody,
in my case in MF 2015 the thickness vba script to get the thickness result as an own result is not working any more.
Same in your case or does anybody has a newer script?
Philipp
5 REPLIES 5
madhukeshwart
in reply to: phammer
It is working fine in 2015
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
mayur_dhumal
Hi Philipp,
Just played macro It is working fine for 3D mesh with 2015.
Mayur
phammer
in reply to: mayur_dhumal
Thanks for the infos,
could anyone please attach the vba script. I think mine is corrupt? Don't know why, but I wil try the other if it works.
Thanks.
Philipp
piepCAE
Could someone please attach the script? Thank you.
Carlos
madhukeshwart
in reply to: piepCAE
Access this following link. It having more details, which you feel interesting & also you can create macro too.
THICKNESS PLOT IN MOLDFLOW COMMUNICANTOR
http://forums.autodesk.com/t5/Simulation-Moldflow-Insight/Thickness-diagnostic-as-a-result-for-MoldF...
Madhukeshwar Talwar
09600060862
