Discussion Groups
Simulation Moldflow Insight
Member
Akshd1191
Sink mark depth result
249 Views, 5 Replies
04-17-2014 09:14 PM
Hi all,
        I'm doing a moldflow analysis using 3D mesh. I'm trying to obtain sink mark index and sinkmark depth results but i'm not getting them. Can anyone please tell me, which type of mesh to be used and which type of analysis sequence to be used to get sink mark index and sink mark depth?
Thanks in advance. :smileyhappy:
Please use plain text.
Distinguished Contributor
mayur_dhumal
Re: Sink mark depth result
04-17-2014 11:40 PM in reply to: Akshd1191
Hello Akash,
If you need both the results available then you will have to go for Midplane mesh or else if you only need 'Sink marks, index' result then you can use DD mesh.
Mayur
Member
Akshd1191
04-18-2014 12:21 AM in reply to: Akshd1191
thank you for your response, I set my model to dualdomain mesh and got sink mark index as you suggested. I tried to generate midplane mesh for my model but i couldn't. So i guess i should accept sink mark index only. can you please tel me what percentage value of sink mark index means?
mayur_dhumal
04-18-2014 01:46 AM in reply to: Akshd1191
Member
Akshd1191
04-18-2014 02:47 AM in reply to: Akshd1191
thank you very much Mayur. link was very helpfull. thank you :smileyhappy:
KaindlJ
04-21-2014 09:10 AM in reply to: Akshd1191
All,
Is it not possible to just use the "sink marks estimate" result, or is this simply not reliable? I'm using this frequently on DD and 3D models and I thought this was essentially the same as the "sink marks, depth" result. After reading the documentation, I may be more confused than when I started.
Jeff
