Discussion Groups
Simulation Moldflow Insight
New Member
klemar05
Simulation of fillers with flake shape
90 Views, 1 Replies
04-09-2013 10:36 PM
Hello we try to simulate some test bodys (Plates 50x50x1,2and3 mm). Our goal is to predict the orientation of zylindrical copper plates.
Now the Question is how to define the filler properties, there you need to specifie a l/d ratio. Our plates are 1µm thick and have an Diameter of 38µm. Is the ratio in this case 38 or is it 1/38?
Has anyone tried to simulated plate shaped fillers yet and can make some suggestions on how ci-value and rsc-value have to been set to reach good results?
Would be great to hear from you.
Thanks in advance
Martin
Please use plain text.
Product Support
nordhb
Re: Simulation of fillers with flake shape
04-10-2013 04:35 AM in reply to: klemar05
regarding aspect ratio for flake and mica fillers:
Aspect Ratio  Reinforcement Type
0< AR < 1        Oblate or disk-like shapes (eg, mica, flakes)
AR > 1             Prolate or cylindrical shape (eg, fiber)
AR = 1             Spherical or cubic shaped fillers
For flakes as in your case it should be 1/38, 0.0263
Berndt
Berndt Nordh
