Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Setting up fill with ram speed over ram position is always faster than reality?
1 REPLY 1
357 Views, 1 Reply
Hi folks,
twice I did set up a real process in moldflow with ram speed (mm/s) over ram position (mm). Both times injection time was much shorter than in the real process?
Any hints why this could be?
Philipp
1 REPLY 1
nordhb
as you get a shorter fill time than expected, it has a higher flow rate than expected.
A reason can be the screw diameter.
Did you set the screw diameter the same as in real process?
It is set at:
Process settings, Advanced Options...
Injection molding machine > Edit...
tab Injection Unit
Machine screw diameter
Hope this helps.
Berndt
Berndt Nordh
