Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Select facing issue
1 REPLY 1
siskomas
330 Views, 1 Reply
Select facing issue
Hello to all,
I'm using sinergy 2014 and when I want to select only the facing triangle mesh with the proper command turned on, this often doesn't work (it didn't work also with the previous versions). Is there a way to fix it?
Thank you.
Francesco
1 REPLY 1
tim.vanast
in reply to: siskomas
I have found similar issues that the face only select will select some of the elements on the other side.  The work around that I have found is that it is sometimes improved to rotate the part a bit.  Then it sometimes selects only the facing element.
Good luck,
Tim
