Show only
Search instead for
I'm using sinergy 2014 and when I want to select only the facing triangle mesh with the proper command turned on, this often doesn't work (it didn't work also with the previous versions). Is there a way to fix it?
I have found similar issues that the face only select will select some of the elements on the other side. The work around that I have found is that it is sometimes improved to rotate the part a bit. Then it sometimes selects only the facing element.
