Discussion Groups
Simulation Moldflow Insight
New Member
KurtHayden8140
Reverting to Dual Domain from a 3D Mesh
355 Views, 3 Replies
05-20-2011 10:44 AM
I used to have a procedure (and probably a macro) to revert to a dual domain mesh from a 3d mesh, however I can no longer find it.  Can someone give me a hand?
Thanks in advance.
Please use plain text.
Employee
yannick.moret
Re: Reverting to Dual Domain from a 3D Mesh
05-23-2011 04:20 AM in reply to: KurtHayden8140
Look in the help, on the contents select :
Modeling-The mesh-Meshing the model- Dual domain mesh, and then look on procedures tab.
Steps are explained how to get a dual domain mesh from a 3D mesh.
Regards
Yannick
Valued Contributor
tim.vanast
05-23-2011 12:13 PM in reply to: KurtHayden8140
It's easy to do.
Change your mesh type back to Dual Domain.  Then mesh your part again.
It can take a while for the remesh, but it always does the trick.
Tim
madhukeshwart
03-29-2013 09:52 AM in reply to: KurtHayden8140
It is already available in moldflow. No nead any macro
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
