Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Reverting to Dual Domain from a 3D Mesh
3 REPLIES 3
KurtHayden8140
553 Views, 3 Replies
I used to have a procedure (and probably a macro) to revert to a dual domain mesh from a 3d mesh, however I can no longer find it.  Can someone give me a hand?
Thanks in advance.
3 REPLIES 3
Look in the help, on the contents select :
Modeling-The mesh-Meshing the model- Dual domain mesh, and then look on procedures tab.
Steps are explained how to get a dual domain mesh from a 3D mesh.
Regards
Yannick
tim.vanast
in reply to: KurtHayden8140
It's easy to do.
Change your mesh type back to Dual Domain.  Then mesh your part again.
It can take a while for the remesh, but it always does the trick.
Tim
It is already available in moldflow. No nead any macro
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
