Discussion Groups
Simulation Moldflow Insight
Active Member
M.Nasir
Relation between mold surface temperature and coolant inlet temperature
246 Views, 4 Replies
05-29-2013 07:41 PM
Hello AMI user..
Please help me to fine the relationship between mold surface temperature and coolant inlet temperature. For example if we want 70deg.C for mold temp., how much temperature for water coolant inlet?
Please advice...
Thank you..
M.Nasir
Please use plain text.
madhukeshwart
Re: Relation between mold surface temperature and coolant inlet temperature
06-02-2013 09:51 AM in reply to: M.Nasir
Generally it should 10 to 20 deg C lesser that of mold surface temperature..
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
madhukeshwart
06-02-2013 09:52 AM in reply to: M.Nasir
one again it depends on your cycle time and rate of coolant flow to get a targer tempearature
Madhukeshwar Talwar
09600060862
Active Member
M.Nasir
06-04-2013 01:39 AM in reply to: M.Nasir
Hi Mr. Madhukeshwar Talwar..
Thank you for your replies and suggestions.
I have one more concern about this topic. In real injection molding machine, the mold temperature will always depend on coolant inlet temp and temp of melt material injected. So, we only can control the mold temp by control on coolant temp and cannot set the mold temp directly. My question is, is it possible if we just set the coolant inlet temp without setting the mold temp in this software?If don't, what is the best options to overcome this problem?
Thank you..
Regards
M.Nasir
madhukeshwart
06-05-2013 07:14 PM in reply to: M.Nasir
Yes. Mold temperature is depending of coolant inlet temperature as well as  flow rate & also cycle time.
In cool analysis, what ever mold surface temperature specified is not used for analysis. It is target mold temperature only.
When you run cool + flow + warp analysis, mold temeprature considered for anlysis is actually average temeprature, which is outcome of cool analysis. i.e Averaged within cycle.
When you run cool(FEM) + flow + warp analysis, Transient cool analyses are used to simulate the change in mold temperature with time, once again depends solver being used.
Madhukeshwar Talwar
09600060862
