Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
No clamp tonnage restrictions in 3D mesh
1 REPLY 1
575 Views, 1 Reply
I recently ran some 3D studies.  I set my maximum clamp force and checked the box for "Do not exceed maximum clamp force".  However, when the studies ran through, they far exceeded the set clamp limitations.  This works in dual domain.  Does 3D not attempt to stay within the specified clamp force?  Thanks for the help.
1 REPLY 1
I am having the same issue.  I looks as if the limitation has not beed added for 3D analysis.  Does anyone know of a way to make this work?  As far as I know, all it does is reduce the pressure during fill/pack to keep the clamp force under the limit.
