Discussion Groups
Simulation Moldflow Insight
Member
秀雙程2963
Mpa and psi value show in the plot of pressure at V/P swithover
204 Views, 2 Replies
03-31-2013 07:20 PM
Hello all,
Is it possible to set the plot value with showing Mpa and Psi in the pressure at V/P swithover?
Please use plain text.
madhukeshwart
Re: Mpa and psi value show in the plot of pressure at V/P swithover
04-01-2013 05:27 PM in reply to: 秀雙程2963
use dual units options.
In options, specify secondary units.
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Member
秀雙程2963
04-01-2013 05:47 PM in reply to: madhukeshwart
thank you very much~
