Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Mpa and psi value show in the plot of pressure at V/P swithover
2 REPLIES 2
秀雙程2963
623 Views, 2 Replies
Hello all,
Is it possible to set the plot value with showing Mpa and Psi in the pressure at V/P swithover?
2 REPLIES 2
use dual units options.
In options, specify secondary units.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
thank you very much~
