Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Moldflow Synergy or Solver
4 REPLIES 4
biricio
2665 Views, 4 Replies
Hi, I'm installing version 2012.
I do not know the difference between these two installations:
Audodesk Moldflow Synergy - User Interface
Autodesk Moldflow Insight Solvers
I come from the 2010 version.
What is the classic version of Moldflow?
thanks
4 REPLIES 4
pierre.masson
in reply to: biricio
Hi Bricio,
Sinergy is the graphic Interface, the one you use to visualize your results, define the process settings work on layers.... You need to have this installed on your working station.
The solver are the ones that compute the Analysis and creates you all there result files that you can find in the project folder.
If you want to work on studies and run analyses locally on your computer, you need to install both, Sinergy and Solver.
If you will run all the analyses on a job server, you can install Sinergy only locally, and install the solver on the job server.
Please mark it as Solution, if this answered your question.
Thank you.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
biricio
Ok, I installed both.
But in the desktop there's write 'Autodesk Moldflow Synergy 2012' and not 'Autodesk Moldflow Insight 2012'.
Right?
nordhb
yes, that is correct.
The user interface icon on desktop is now called Autodesk Moldflow Synergy 2012.
Berndt
Berndt Nordh
I just came to know that Autodesk Moldflow 2014 Has been launched...
I want to understand that,  what are the changes has been made in new version????
let me know
