Moldflow Insight Forum
Welcome to Autodeskā€™s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Moldflow Communicator
1 REPLY 1
671 Views, 1 Reply
I will appreciate if someone can tell me producer to compare (2) 'mfr' report file in communicator. Procured in help is not working
1 REPLY 1
petr_AL
as I know, only two studies in one .mfr file are possible to compare in Moldflow Comunnicator, not two different .mfr files.
If you select two studies at Moldflow Insight to export (using Ctrl) to .mfr, you will have both in the one .mfr file.
More then 2 studies is not possible to export together.
Petr
