I have a problem with running moldflow simulations, while Insight is working fine.
I have a license server running on second workstation (with 3 Insight licenses and one synergy). When I try to run a simulation , an error window shows up (in the attach. )
The only message I've found is "Couldn't execute C:\Program Files\Autodesk\Simulation Moldflow Insight 2013\\bin\mhb3d -gpu -mes raw -fill " in the working directory.
Running Synergy on the license server directly works just fine.
