Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Mold thermal Expansion
2 REPLIES 2
501 Views, 2 Replies
HI everybody,
I know what mold thermal expansion means. But how does this effekt excactly the simulation.
Does anybody knows more.
Greetings Philipp
2 REPLIES 2
nordhb
I assume you mean the setting of:
Consider mold thermal expansion
which is if you want Warp analysis to consider the effect of mold thermal expansion on the warpage and/or molded-in stress levels in the part.
During injection molding, the mold expands as the temperature increases, causing the cavity to become larger than its initial dimensions.
This cavity expansion helps to compensate for part shrinkage during cooling, resulting in actual shrinkage that is smaller than that predicted without accounting for thermal expansion of the mold.
Note: If you use this option, ensure that a suitable mold material has been selected.
This is where the key material property used by this option - the coefficient of thermal expansion of the mold - is defined.
Hope this clarifies.
Berndt
Berndt Nordh
madhukeshwart
Most of the materials used for injection molding will have less thermal expansion.
Like P20, H13 grades.
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
