Solved by madhukeshwart. Go to Solution.
Hello Erick,
Would you please elaborate what you are looking for?
Are you looking to learn about the problem and solutions itself ?
Or how to simulate it?
Ana Maria Marin
Training Content Manager at Autodesk
Jetting modeling requirements
To simulate jetting, both the model must be set up to predict it, and adjustments to the analysis options must be set.
The model must have the following:
The flow solver advanced options must be set including:
1. Inertia must be checked.
Advanced option > Solver Parameters > Fill + pack Analysis > Solver parameters > check - Simulate inertia effect & Simulate Gravity effect
2. Intermediate results must be set with small time increments.
Advanced option > Solver Parameters > Fill + pack Analysis > Intermediate results > Write at specified times > Edit times.
( Use a very small time increment such as 0.01 to 0.02 seconds initially)
3. Start at time the polymer is getting to the gate. Continue with a very fine increment until the flow front is well developed.
A preliminary fill analysis can be used to determine these times.
Here is link which explains how to to simulate Jetting in moldflow ..
