Are you using "Dynamic Feed Control" for fill control
This feature uses pressure controllers at each gate in a mold, and Autodesk Moldflow Insight can simulate . Signals come from the pressure sensors of the hot runner system(s) to control multiple hot runner valve gates dynamically, in order to achieve a pre-determined pressure profile for each gate.
The general machine controller, or the central controller, is set to use a high (usually maximum) pressure, to ensure the flow-rate requirement for injecting the melt through the multiple valve gates controlled by the individual pressure controllers. There is no velocity/pressure switch-over, as there is no velocity control stage.
The application is typically used for multi-cavity and family molds, and for multi-gated large part injection moldings, in particular.
The current manufacturing set-up procedure is to use trial-and-error for an individual cavity to get a desired pressure profile as a "finger-print", and then apply it to individual valve gate controllers for the multi-cavity case. For a multi-gated large part, it is difficult to set up, which makes the software simulation very important beforehan
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
