While Running Injection & Pressure Optimization Analysis , I get following error messages. I will appreciate someone can help to resolve the issue
Injection & Pressure Profile Optimization Analysis
** ERROR 1300360 ** Unable to read temperature results (1770) from OF1 file.
4 0.0000 0.0000 1.5633E+05 2.6290
Determining Optimal Pressure Phase...
** ERROR 1300370 ** Unable to read fill time results (1610) from OF1 file.
** ERROR 1300500 ** An error occurred launching a flow analysis. The process
optimization analysis cannot continue.
** ERROR 1300100 ** Optim solution failed.
Mukund Mehta
Hi, Mukund
It is sometimes happend with optim and runner balance analyses. Both analyses start a significant number of flow simulations, then read result files back to get the optimum. Theoretically they should attept to read result files after the job manager reported that the simulation results are written to disk. Unfortunately due to some glitches ( Windows' or Job Manager's) the optimization routine gets the signal that the simulation results are written when they actually are still in writing. The optimizer cannot get the simulation results and stops. Usually those errors disappear if the optimization is relaunched.
A few measures that help with those problems:
Thanks for quick reply. My Comments for suggestion are
There are plenty of free disk space for your project directory and temporal file directory yes, 350 GB
