HI everybody,
I did two weeks in moldflow teaching but I still lack of many information.
Are there some Information how to use constraints and loads in the boundary condition tab.
I know how to use fixed constraints for core shift analysy.
But what is with pin, spring and general constraints. And how to use loads?
What information can I get out of using loads.
Greetings
Solved by nordhb. Go to Solution.
there is a module called Stress in Autodesk Simulation Moldflow Insight for structural analysis in Midplane mesh type.
You can run only Stress itself, or in conjuction with (Cool+) Fill+Pack (+Warp).
For Stress you can apply boundary conditions Constriants and Loads. You can also do this for Warp.
Note: for Midplane mesh type
Please, see Help:
ASMI Help > User's Guide > Analysis sequence > Stress analysis >
for further information.
Or some fromwikihelp:
http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Help/Insight/2891-Analysis2891/3304-Stress...
About constraints:
About elemental loads:
Hope this helps.
Berndt
