Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How to restrict nodes freely move at +ve direction only along same axis?
1 REPLY 1
Chong_CY
420 Views, 1 Reply
I'm running a core shift analysis of a overmould part.
Overmould material wrap Part Insert on both core and cavity side with limited holding area which constrainted by mould. Portion of Part Insert direct contact with core metal, it is to be filled with overmould material at mapping cavity side.
How should I restrict nodes freely move at +ve direction (cavity side) but not -ve direction (core side) along same axis?
1 REPLY 1
PascalGosset
in reply to: Chong_CY
It is not possible.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
