In the different XX, YY and ZZ vectors you can go to the properties and in the tab Deflection you can unmark the vectors you don't want to see the deflection.
For example, when you check "Deflection, all effects:X Component" you see the deflection in the 3 axes. So, you go to the properties and in the tab Deflection you unmark Y and Z directions. Now you just see the deflection in XX direction.
When you choose "Deflection, all effects:Deflection" you also can check the deflection in the different axis. You just need to choose the "Examine Result" in the Results toolbar and then pick in the part (wait a moment). A board will appear with the information about the point you pick (postion before deflection, after deflection and the deformation vector). Normally I use them to make my reports. Like that, my costumer will know the deflection of the most important points.
I hope that these informations will help you...!!!
Best regards,
Engº. Gonçalo Rodrigues
MOLIPOREX, S.A.
Portugal
