Good day,
I have been studying on a project that has a lot of prisms on the inner surfaces. Even thought, I try several times,quality of mesh is very low which is %54. Please find the picture of the part attached. How can I increase the quality of mesh for these kind of parts?
Thank you
With the geometry of your part, you can't increase the mesh match percentage because all of your element "sawtooth" are unmatched (use the function : Mesh ==> (in mesh Diagnostic) Mesh Match for know if your element are Matched, Edge or Unmatched and check if your prisms are unmatched). And with this geometry you could have problems with thickness in Dual Domain.
For me, if you want good results, mesh your part in 3D.
Regards
It will be IMPOSSIBLE to get mesh match around ~85-90% for this type of part, so even if you mesh with small edge length it will not possible to get desired mesh match, also when simulate this part with DD mesh it is likely that temperature drop will be high & you may get short-shot, you will need high injection speed machine & part need to be injected with very high speed to nullify chances of temperature drop.
Instead try with 3D, more accurate results, fast results. Just mesh with DD (try to lower down the aspect ratio, as much you can) & then mesh in 3D, because thickness of part is varying from 2-7mm. so 3D is best for this part.
Mayur
Around serration zone , it can’t match both faces, but can be improved
It will sure improve mesh match & but may not be expected for Dual domain requirement . Such situation better to convert the DD mesh in 3D mesh.
