Discussion Groups
Simulation Moldflow Insight
Active Member
M.Nasir
How to calculate Deflection, all effects: Deflection from X, Y and Z component
409 Views, 7 Replies
05-28-2013 12:28 PM
Hi everyone,
I was analyze a component using 3D mesh to get the warpage result. From the results shows 4 difference results, which is Deflection, all effects: Deflection, Deflection, all effects: X, Y and Z component. I can understand for every component that depending on their axis for X, Y and Z. But, what is Deflection, all effects: Deflection tell about and how to calculate its value from X, Y and Z component results.
Please help me..
M. Nasir,
Malaysia
Please use plain text.
romslayer
Re: How to calculate Deflection, all effects: Deflection from X, Y and Z compone
06-03-2013 12:46 AM in reply to: M.Nasir
Hello Nasir,
I have an idea about the calcul of Deflection all effect, It's very easy.
Moldflow calcul the difference between before and after deformation for X, Y and Z component. After he calcul the quadratic sum of this vector.
Example :
Node1 : (X1after;Y1after;Z1after)-(X1before;Y1before;Z1before)=(X1after-X1before;Y1after-Y1before;Z1after-Z1before) ==> (X1component;Y1component;Z1component)
Now, you calcul the quadratic sum of the X,Y and Z component to obtain the Deflection all effect.
Deflection All effect = Sqrt(X1component²+Y1component²+Z1component²)
I think it's that, but other can confirm this.
Hope this help
Romslayer
Active Member
M.Nasir
Re:How to calculate Deflection, all effects: Deflection from X,Yand Z component
06-04-2013 02:04 AM in reply to: M.Nasir
Hi Romslayer,
Thank you for your response..Do you mean the calculation had done for every node?Then the results shows the deflection for sqrt Xsq+Ysq+zsq for each node..I think it is reliable.
Where you found the solution?..I mean from any books or journals, because I need to cited that equator on my thesis..
Thank you so much...
Regards..
M.Nasir
romslayer
Re: Re:How to calculate Deflection, all effects: Deflection from X,Yand Z compon
06-04-2013 11:06 AM in reply to: M.Nasir
Yes, I think the calculation had done for each node.
I have work on this topic before, it's for that I know the answer.
It's a really basic geometrical calcul. It's pythagorean theorem (Euclidean distance).
the first point (A) is the nodeX before deflection and the second point (B) is the nodeX after deflection.
A(x1,y1,z1) and B(x2,y2,z2)
To calcul the distance between the point1 and 2, you use this equation in cartesian
|AB|=sqrt[ (x2-x1)²+(y2-y1)²+(z2-z1)² ]
Hope this help
Romslayer
Valued Contributor
nishit78
06-19-2013 05:13 AM in reply to: M.Nasir
According to moldflows help section, Part distortion happens due to differential cooling, shrinkage, and orientation.
Deflection all-affects basically combines the deflection due to each of these individual factors to show you the final result.
romslayer
06-19-2013 09:09 AM in reply to: M.Nasir
Yes it's true, and you can see that if you select "isolate cause of warpage" in the process settings but the question is "how to calculate deflection, all effect from X,Y and Z component and I'm agree with my explanation in this thread.
Valued Contributor
nishit78
06-19-2013 09:35 AM in reply to: romslayer
Romslayer,
I misunderstood the question and I too agree with what you said. I did edit my previous comment to correct myself. I am in agreement with you about how it is calculated.
romslayer
06-19-2013 03:28 PM in reply to: M.Nasir
Sorry, I just saw the answer in my mailbox and I don't see the edited post in the topic :smileyhappy:
Regards
