Discussion Groups
Simulation Moldflow Insight
Active Member
be4dawn
How can I predict stack-mold clamp force???
191 Views, 3 Replies
06-16-2014 12:20 AM
I wonder about how to predict stack mold clamp force.
also wondering ask you about how to present that result(clamp force : XY plot) in synergy.
please answer to me, if anybody know that.  thanks.....
Please use plain text.
Employee
Alex.Bakharev
Re: How can I predict stack-mold clamp force???
06-16-2014 02:33 AM in reply to: be4dawn
There is a check box on the properties of the dialog for editing elemental properties "Exclude from the clampt force calculations". Use it to exclude all the cavities but the last one, the closest to the movable plate of the molding machine.
Active Member
be4dawn
06-16-2014 10:50 PM in reply to: Alex.Bakharev
thanks for your answer.
I aleady know that method, but I think between upper part and lower part are not exactly same that method is not true.
If Upper part and Lower part is not same, what can I do???
could please tell me good solution....
madhukeshwart
06-17-2014 04:02 AM in reply to: be4dawn
As Mr. Alex explained, that is the only method available now.
"There is a check box on the properties of the dialog for editing elemental properties "Exclude from the clamp force calculations".
Use it to exclude all the cavities of all levels, which  having smaller projected area.
Then only those  level cavities, which having larger projected area will be used for clamp tonnage calculations
Madhukeshwar Talwar
FIAT-CHRYSLER ATC, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
