I've discovered the studymod.exe program to modify SDY files. The help mention a XML file, but I'm not able to find any description or guide about that XML file.
What's the purpose? Any example?
Juan Zamora
Solved by nordhb. Go to Solution.
you have information in the Help system:
Autodesk Simulation Moldflow Insight 2014:
ASMI Help > User's Guide > Command line control > Editing a Moldflow study file > The Modifier file
or
The modifier file ( <ModifierFile>) is an XML file describing the changes you want to apply to the original study file.
Follow the links of:
Boundary conditions
Mesh
Process Settings
and you will find some examples.
Hope this helps.
Berndt
