Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Hint for studymod usage
1 REPLY 1
juanramon.zamora
585 Views, 1 Reply
I've discovered the studymod.exe program to modify SDY files. The help mention a XML file, but I'm not able to find any description or guide about that XML file.
What's the purpose? Any example?
Juan Zamora
1 REPLY 1
nordhb
in reply to: juanramon.zamora
you have information in the Help system:
Autodesk Simulation Moldflow Insight 2014:
ASMI Help >  User's Guide > Command line control > Editing a Moldflow study file > The Modifier file
or
http://help.autodesk.com/view/MFIA/2014/ENU/?url=/cloudhelp/2014/ENU/MoldflowInsight360/files/GUID-B...
The modifier file ( <ModifierFile>) is an XML file describing the changes you want to apply to the original study file.
Follow the links of:
Boundary conditions
Mesh
Process Settings
and you will find some examples.
Hope this helps.
Berndt
Berndt Nordh
