Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Grow from results
4 REPLIES 4
767 Views, 4 Replies
Grow from results
I am having problems getting a sensible looking 'grow from' result. I am running a test strip with 5 valve gate which seem to work ok however the results on the parts show just one colour. The attached shows 5 injection locations. I did have just one with a runner system but it makes no difference. I have animated the 'flow rate, beam' result and I can see the flow rate shifting from gate to gate. The gates are timed to open when the flow front reaches the gate node.
I am having to run using version 6.2.
Note I tried running the tub valve gate example from the UK training examples and again the 'grow from' result looks wrong.
Anyone have any thoughts? What am I doing wrong? Am I doing anything wrong?
4 REPLIES 4
GalSherbelis7635
This is how it works with valve gates. If you open each gate just before (two rows of elements) the flow front reaches it I think you will see different picture.
Gal
madhukeshwart
Start creating a gate one by one , creat one gate first , get it mesh . Then creat second gate and mesh it , then third , fourth , fifth ...repeat the
steps .
Then run the analyis .
It may give effect of each gate & but I'm not sure with valve gating ....
Please reply after doing the analysis
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
ericli
I think it's bring about the rule of grow from result how to be create, I have tested if the gate is open before the flow front, the grown from is difference.
Valve gating will not show effect of each gates through ' Grow From' Plot
Madhukeshwar Talwar
09600060862
