Is there any documentation on installing and configuring Moldflow to work with MS HPC server?
Ray
Dear Autodesk Team,
Would like to know wheter Moldflow can be integrated with Windows/LInux Cluster with a work load manager.
If yes, please let us know the use case or the documentation.
Thank you
AP
I don't think you will find instructions on how to set this up. The Moldflow job manager was not built to work with external job managers/load balancing programs.
Having said that, the moldflow analysis jobs can be run from a 'command line' using a 'runstudy' command ("runstrudy modelname.sdy"), which could some basic functionality for you to work with. You find more informaiton on this in this link. I hope this works for you but as mentioned before, the Moldflow products was not developed to work in an HPC/Cluster environment so there may be limitations.
Would like to ask additional questions here:
1. Whether Moldflow is available with Autodesk 360 ?
2. If yes, Whether it is used for Moldlow Analysis only?
3. Request details of Moldflow on Autodesk 360
Thank you
Good question!
Autodesk 360 is actually a cloud-based data storage service (includes 3Gb of free data storage). This does not include software or software products though.
I suspect however you are referring to Autodesk Simulation 360 though, which is a cloud simulation analysis service. The widely published version of Autodesk Simulation 360 contains Mechanical simulation and CFD (Computational Fluid Dynamics). A lesser published version contains Moldflow Insight capabilities, but is only available through Autodesk direct sales channels at this stage and may not be available in all countries.
There is an help entry for a cluster running on thin clients in linux....but in the past the linux version was a litle bit limited vs windows solvers....my 5 cents
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-C9739CC5-BC78-40F6-BE0B-2E8C8FA589FD
