Moldflow Insight Forum
Welcome to Autodeskā€™s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Showing results forĀ
Did you mean:Ā
Free Edges and Non Manifold Edges Results in Midplane Model.
2 REPLIES 2
828 Views, 2 Replies
Hi!
I have a problem meshing a model of Basket in Midplane. The following images show the results of Free Edges and Non-Manifold Edges, throw by the diagnostic tool of the program. I canĀ“t understand this results. What steps should I take if these results are a problem?. The piece have a max thickness of 5 mm, localized in the ribs.
I know that, for midplane, Free Edges and Non-Manifold Edges can be different of 0.
Any advice is welcome and appreciated.
Thanks for Help!
Mata.
2 REPLIES 2
PascalGosset
You didn't do anything wrong. It's a trouble of Midplane.
The only way is to correct manually the mesh errors.
As your part is symetric, you can work on a quarter and copy it once the corrections done.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old šŸ˜‰
Ok, thank you very much. I am alredy solving problems manually.
Regards.
Mata.
