Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Export Node and Information
1 REPLY 1
phammer
321 Views, 1 Reply
HI everybody,
I want to export the nodes and the density at the end of the cycle.
is this possible to export the date in all nodes in one time step?
Greetings
Philipp
1 REPLY 1
nordhb
in reply to: phammer
for 3D mesh type Density result you can do as follows:
1. Select the result Density
2. Go to tab Results
3. Click Export and Publish
4. Select Patran
This will export density at nodes for all time steps.
One file for each time step.
Another route for the same export command:
2. S > Publish > Plot Data in Patran Format.
Hope this helps.
Berndt
Berndt Nordh
