Dear community,
I am currently having the problem that the analysis I want to start fails. I am getting the usual message about the failure (see attachment). However, as you can see in the pic, the analysis log is completely empty. This holds for Autodesk Simulation Moldflow Insight 2014 and 2015. So, how am I supposed to know what's the reason for the failure?!
Has anybody experienced the same? Or does anyone even have a solution?
Background information:
OS: Windows 7
Moldflow: Insight 2015/Insight 2014
Analysis: Cool(FEM)+Fill+Pack+Warp
Model type: 3D
Number of elements: 1 mio. for part, 1.5 mio. for cooling, 2.5 mio. for mold
I am looking forward to your comments, thanks already for your help!
Solved by maxmarautodesk. Go to Solution.
I should add that the solution server for Simulation CFD is up and running in the background.
Besides, a pure fill study with the exact same model does work.
You need to install Insight 2015 package after Synergy has installed.
If you need any help please let me know.
Mayur
Hey Mayur Dhumal,
thanks for your advice. Nevertheless, it was not of great help, since I have installed Synergy first and Insight afterwards from the very beginning. Still, the problem came up. Moreover, the problem changed now (for whatever reasons). The Analysis Log box is not completely empty anymore. The analysis still fails and is aborted. The folling text appears now (due to confidentiality, I have overwritten the computer and file names):
Copyright Autodesk, Inc. All rights reserved.
(C)2009 2010 2011 2012 2013 2014
Portions of this software are covered by U.S. Patent Numbers 5,287,408 and 6,096,088.
Cool(FEM) Solver.
Version: ami2015-promethium_compile_windows-x64 (Build 14104-714)
64-bit build
Analysis running on host: xxxxxxx
Operating System: Windows 7 Service Pack 1
Processor type: GenuineIntel Intel64 Family 6 Model 58 Stepping 9 ~2392 MHz
Number of Processors: 8
Total Physical Memory: 16257 MBytes
Analysis commenced at Tue Jul 15 16:22:15 2014
Mesh and boundary conditions file name : xxxxxxxxxxxxxxxxxxx.udm
Results files core name : xxxxxxxxxxxxxxxxxxx
Help of any kind is very much appreciated, because I am really stuck here!
Hey all,
It seems to work now, for whatever reason. I had installed Insight after Synergy, but I did a reinstall of both Synergy first and Insight second to be sure. Perhaps, you were also right about the license problems. It remains a mystery. I can only recommend to all people having the same trouble to try to uninstall the whole Moldflow software and than reinstall
1. Synergy
2. Insight
3. All available updates
Best regards,
Max
