Discussion Groups
Simulation Moldflow Insight
kgonzal5
** ERROR 302090 ** Part has zero volume.
203 Views, 4 Replies
04-11-2013 02:59 PM
Hello.
I've have modeled a four cavities model, ran it already without runners, just with the four injection points, and it completes satisfactorilly, nevertheless, when adding a runner system, the error in the title appears
Already deleted runners and constructed from zero about three times, and same mesage appears.
Any idea?
Thank you
Please use plain text.
kgonzal5
Re: ** ERROR 302090 ** Part has zero volume.
04-12-2013 12:00 PM in reply to: kgonzal5
Changed the diameter of beams, cause I thought material was too thick for a tiny diameter, and now this error is comming:
** ERROR 302115 ** Beam radius is zero.
Check the mesh and assign positive radii to all beams
and run the analysis again.
Made already the beam L/D radii diagnoses, trapped beams and nothing appears to be wrong.
Product Support
nordhb
04-14-2013 11:22 PM in reply to: kgonzal5
when you do a thickness plot, do you see the 0 thickness elements?
Or do you see the label having 0 as minimum thickness?
You can also place 0 thickness elements on a specific layer, when doing thickness diagnostics, to identify 0 thickness elements.
Berndt
Berndt Nordh
kgonzal5
04-15-2013 12:20 PM in reply to: nordhb
Does it apply as well for a 3D model? Thickness diagnosis is not enabled. I didn't found any tetra missing or internal edges.
Product Support
nordhb
04-16-2013 12:12 AM in reply to: kgonzal5
for 3D you have the mesh diagnostics Dimensional in tab Mesh.
Click the small arrow down to the right of "Mesh Diagnostics" to find comman Dimensional.
The Dimensional diagnostic is used to view model dimension values in a 3D mesh.
Dimensions are calculated based on the normal of each element.
This means you can get high dimension thickness on edges that has normal to an opposite edge.
You can scale and put on separate layer.
Hope this helps.
If you need furhter assistance, the study is needed for troubleshooting.
Berndt
Berndt Nordh
