Does any one know what is causing this error. I get it after the fill and pack finishes just before the warp starts.
** ERROR 201430 ** Warp analysis failed while finding solution to multi-point constraint equations.
Improve the mesh quality and run the analysis again.
Mesh Type = Dual Domain
Mesh match percentage = 88.8 %
Reciprocal mesh match percentage = 85.0 %
Total number of nodes = 53898
Total number of injection location nodes = 1
The injection location node labels are:
123300920
Total number of elements = 107408
Number of part elements = 106968
Number of sprue/runner/gate elements = 440
Number of channel elements = 0
Number of connector elements = 0
Parting plane normal (dx) = 0.0000
(dy) = 0.0000
(dz) = 1.0000
Average aspect ratio of triangle elements = 2.9272
Maximum aspect ratio of triangle elements = 29.8977
Element number with maximum aspect ratio = 50712
Minimum aspect ratio of triangle elements = 1.1551
Element number with minimum aspect ratio = 110705
Total volume = 126.7494 in^3
Volume filled initially = 53.9552 in^3
Volume to be filled = 72.7942 in^3
Part volume to be filled = 71.5906 in^3
Sprue/runner/gate volume to be filled = 1.2036 in^3
Total projected area = 374.9242 in^2
This error is mesh related in nature so this is where I'd focus your efforts. Basically, a node can only have so many neighboring nodes connected to it or else the Warp solver will not be able to maintain the constraint equations. The error is rare and I usually only see this happen on overmolding analyses.
This is typically a result of having a poor mesh, but your mesh does not seem to raise any "red flags" from what I can see in your statistics.
My second recommendation would be to refine your mesh a little further to see if that will resolve the issue.
If this does not work then I'd recommend contacting your local support team so that the model can be investigated further.
Thank You,
Shawn
we did try and fine the mesh out but were not successful
can you please provide the contact information of the person we would need to get in touch with to review this mesh
This problem seems to happen when you make copy's of your beam and part elements. Im finding this very annoying when trying to run a series of iterations with different layouts and gate strategies. I believe this is a bug in the software and needs to be addressed. There has to be a way the software can detect this problem before it actually runs the analysis. I can't keep wasting time remeshing my models especially after analyzing day to only discover that the warp solvers failed.
Jeff
