i am following these instructions:
Compression molding analyses require both a part mesh and an initial charge mesh for simulation.
I am using a prt file from Creo for the charge, however when i get to step 4 i am unable to asign an 'initial charge (3D)' that option is simply not available
should i be using an assembly with the final part and charge in the same file?
any guidances on this will be appreciated
David
Solved by Paul.Larter. Go to Solution.
Hello David
Can you please check if you have changed the Molding process to 'Thermoplastic compression molding' or 'Reactive compression molding' on the Home tab - Molding Process Setup.
This will then give you the property option 'Initial charge (3D)' when you select assign property.
Regards
Paul
